[QGIS-trac] Re: [Quantum GIS] #1487: QGIS fails to recognise Shapefile projection
Quantum GIS qgis at qgis.org
Wed Aug 19 05:20:10 EDT 2009
        Reporter:  marisn                            |         Owner:  nobody
            Type:  bug                               |        Status:  reopened
        Priority:  major: does not work as expected  |     Milestone:  Version 1.2.0
       Component:  Projection Support                |       Version:  1.2.0
      Resolution:                                    |      Keywords:
Platform_version:                                    |      Platform:  Gentoo
        Must_fix:  No                                |   Status_info:  0
Changes (by marisn):
  * status:  closed => reopened
  * version:  1.0.0 => 1.2.0
  * resolution:  fixed =>
  * milestone:  Version 1.0.2 => Version 1.2.0
Comment:
 Still fails with QGIS 1.2.0 (r11429). Related question - why QGIS SRS
 definition differs from one created by OGR?
 Here's console output:
 Critical: QgsCoordinateReferenceSystem::createFromWkt -- theWkt is
 uninitialised, operation failed
 Warning: QMetaObject::connectSlotsByName: No matching signal for
 on_btnHelp_clicked()
 Warning: QgsCoordinateReferenceSystem::getRecord failed :  select * from
 tbl_srs where parameters='+proj=tmerc +lat_0=0 +lon_0=24 +k=0.9996
 +x_0=500000 +y_0=-6000000 +ellps=GRS80 +units=m +no_defs'
 Warning: QgsCoordinateReferenceSystem::findMatchingProj ------->
  no match found in srs.db, trying user db now!
 Warning: QgsCoordinateReferenceSystem::findMatchingProj -------> no match
 found in user db
 on_btnClose_clicked()
 found in user db
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1487#comment:6>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
