[QGIS-trac] [Quantum GIS] #1900: windows: qgis crashes after closing a GRASS mapset
Quantum GIS qgis at qgis.org
Wed Aug 26 14:54:43 EDT 2009
   Reporter:  lutra                                      |              Owner:  nobody
       Type:  bug                                        |             Status:  new
   Priority:  critical: causes crash or data corruption  |          Milestone:  Version 1.3.0
  Component:  Data Provider                              |            Version:  HEAD
   Keywords:                                             |   Platform_version:
   Platform:  Windows                                    |           Must_fix:  No
Status_info:  0                                          |
 I can see the following behaviour with some data (the qgis sample dataset
 for example). I'm using qgis dev version (1.3) installed via osgeo4w.
 To replicate do the following:
 *) open the qgis sample (GRASS) dataset
 *) add a vector layer
 *) close the GRASS mapset (without removing the GRASS vector layer)
 *) close qgis (file -> exit)
 it is first thrown a warning "variable LOCATION_NAME not set" that appears
 also under linux, but then under windows the program crashes. See attached
 image.
 Not really sure to what component assign this ticket.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1900>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
