[QGIS-trac] Re: [Quantum GIS] #1903: Wrong query to WMS
	(WMS.GetFeatureInfo)
    Quantum GIS
    qgis at qgis.org
    Fri Aug 28 10:58:35 EDT 2009
#1903: Wrong query to WMS (WMS.GetFeatureInfo)
        Reporter:  alexbruy                          |         Owner:  mhugent
            Type:  bug                               |        Status:  closed
        Priority:  major: does not work as expected  |     Milestone:  Version 1.3.0
       Component:  WMS+WFS                           |       Version:  HEAD
      Resolution:  fixed                             |      Keywords:
Platform_version:                                    |      Platform:  All
        Must_fix:  No                                |   Status_info:  0
Changes (by jef):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Replying to [ticket:1903 alexbruy]:
 > In line QUERY_LAYERS instead of '''174A''' must be semicolon (''':''').
 Also there is duplicated '''SERVICE=WMS'''
 Fixed in r11522
 - the double {{{SERVICE=WMS}}} is harmless.  The WMS server probably
 shouldn't already include  {{{SERVICE=WMS}}} in it's {{{OnlineResource}}}
 in the {{{GetCapabilities}}} response.
 - the other problem was that the percent encoding turned that colon in
 your layer into {{{%3A}}} and the {{{%3}}} was in turn wrongly replaced
 with the x coordinate.
 - the WMS provider now also treats the WMS response a UTF-8.  That should
 be harmless when it's plain ascii and helps in your case.  I now get:
 WMS identify result for 375, 289:
 Results for FeatureType 'veg':
 the_geom = [GEOMETRY (MultiPolygon) with 6832 points]
 TYPE = ЛУГОВЫЕ СТЕПИ И ОСТЕПНЕННЫЕ ЛУГА
 SUBTYPE = Разнотравно-злаковые и злаиово-разнотравные мезофитное и
 ксеромезофитное разнотр
 Whatever that means ;)
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1903#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
