[QGIS-trac] [Quantum GIS] #2176: OGR converter: CSV export is broken
Quantum GIS qgis at qgis.org
Wed Dec 2 09:02:12 EST 2009
   Reporter:  neteler                                    |              Owner:  nobody
       Type:  bug                                        |             Status:  new
   Priority:  critical: causes crash or data corruption  |          Milestone:  Version 1.4.0
  Component:  Build/Install                              |            Version:  HEAD
   Keywords:                                             |   Platform_version:
   Platform:  Debian                                     |           Must_fix:  No
Status_info:  0                                          |
 In trunk, the conversion of a SHAPE file (points) to CSV fails. It creates
 an empty ASCII file.
 Additionally, the button description is felt to be confusing: "Dataset"
 does not indicate that a directory is meant.
 Second bug: if the "Dataset" directory already exists, the converter fails
 with "Failed to create...". In the shell terminal a message is seen that
 it already exists: it would be important to catch this directory-present
 error and ask the user to suggest a different name.
 "Layer" as button description is also unclear (for CSV): indeed a file
 name is meant.
 See also attachment.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2176>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
