[QGIS-trac] [Quantum GIS] #2229: Adding memory option for r.watershed
Quantum GIS qgis at qgis.org
Wed Dec 9 13:36:37 EST 2009
   Reporter:  lucacasagrande    |              Owner:  pcav
       Type:  enhancement       |             Status:  new
   Priority:  minor: annoyance  |          Milestone:  Version 1.4.0
  Component:  Build/Install     |            Version:  1.3.0
   Keywords:  grass             |   Platform_version:
   Platform:  Windows           |           Must_fix:  No
Status_info:  0                 |
 Hello folks,
 today we did a workshop using Qgis and GRASS plugin on windows machine.
 Running r.watershed module failed with an error using both 1.3 and 1.4
 from Osge4W, so I had to use the shell and add the option -m (Enable disk
 swap memory option) to the command line.
 This solved the issue.[[BR]]
 Do you think that it's possible to add this option to the module's
 GUI?[[BR]]
 I think that some windows errors are related to memory management..
 Thanks
 Luca
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2229>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
