[QGIS-trac] [Quantum GIS] #2301: problem when editing adjacent polygons and "enable toplogical editing" not active
Quantum GIS qgis at qgis.org
Sat Dec 19 20:39:44 EST 2009
active
   Reporter:  lutra                             |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.4.0
  Component:  Digitising                        |            Version:  HEAD
   Keywords:                                    |   Platform_version:
   Platform:  All                               |           Must_fix:  Yes
Status_info:  0                                 |
 Take two adjacent polygons and check that in the project properties the
 "enable toplogical editing" option is not enabled.
 With the node tool select one node of the sahred border and move it above
 the other polygon.
 As a result the reshaped area stays under the other polygon instead of
 above. The new position of the node is marked but is like a point.
 See screenshot.
 Tested on trunk.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2301>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
