[QGIS-trac] [Quantum GIS] #2304: In GRASS plugin, r.water.outlet is not working
Quantum GIS qgis at qgis.org
Sun Dec 20 04:21:27 EST 2009
   Reporter:  micha                             |              Owner:  rugginoso
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.4.0
  Component:  GRASS                             |            Version:  1.3.0
   Keywords:  hydrological analysis, basin      |   Platform_version:  Win32 Ubuntu 9.10
   Platform:  All                               |           Must_fix:  No
Status_info:  0                                 |
 I cannot get expected results with the r.water.outlet GRASS module in QGIS
 1.3.0. I've tried in a few different locations, on both win and linux
 setups, and I always get a uniform raster with value 0 covering the whole
 region.
 I recall this working properly in earlier versions of QGIS (pre-1.0)
 To duplicate the issue:
 In the North Carolina database, run r.watershed using the elevation raster
 to create flow direction, streams and catchments rasters. Then run
 r.water.outlet using the resulting flow direction, and a drainage outlet
 point on the streams raster. Results are always a black raster covering
 the whole region.
 Working in GRASS, outside of QGIS, using the same GRASS database, flow
 direction, and same easting-northing values results in a correct drainage
 basin.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2304>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
