[QGIS-trac] [Quantum GIS] #2311: Print composer template creates identically named composer items
Quantum GIS qgis at qgis.org
Tue Dec 22 14:42:54 EST 2009
   Reporter:  jctull                            |              Owner:  mhugent
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.4.0
  Component:  Printing                          |            Version:  HEAD
   Keywords:  print composer template naming    |   Platform_version:
   Platform:  All                               |           Must_fix:  No
Status_info:  0                                 |
 If you create a composer item, save it to a template, then load the
 template again, the composer item name is identical and you compromise
 access to the two identically named composer items from the "Print
 Composers" menu item. The new composer item should get an index number
 appended or some other method of producing a new composer item uniquely
 named relative to the already existing one.
 Currently, you will see and have access to only one of the composer items
 under the "Print Composers" submenu. You have to go to the "Composer
 Manager" to be able to access each composer item. You can rename from
 there to work around the issue manually.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2311>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
