[QGIS-trac] [Quantum GIS] #2329: Old symbology: unique value doesn't use the size based on map unit
Quantum GIS qgis at qgis.org
Mon Dec 28 01:54:29 EST 2009
   Reporter:  trapanator                                 |              Owner:  nobody
       Type:  bug                                        |             Status:  new
   Priority:  critical: causes crash or data corruption  |          Milestone:  Version 1.4.0
  Component:  Build/Install                              |            Version:  HEAD
   Keywords:                                             |   Platform_version:
   Platform:  Debian                                     |           Must_fix:  No
Status_info:  0                                          |
 This bug is similiar to #2318. But there's one difference:
  1. If you check "map unit" without classification, map symbols are scaled
 correctly[[BR]]
  1. if you check "map unit" '''WITH''' classification, map symbols are
 '''NOT''' scaled[[BR]]
 steps to reproduce:
  1. load a point layer[[BR]]
  2. open symbology properties (the old)[[BR]]
  3. select "unique value"[[BR]]
  4. get all values for a field[[BR]]
  5. select a value[[BR]]
  6. set the size and check the "map unit")[[BR]]
  7. click OK [[BR]]
  8. '''ZOOM IN / OUT'''[[BR]]
 the symbols are never scaled
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2329>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
