[QGIS-trac] Re: [Quantum GIS] #1479: map composer: adding scalebar when view is added crashes qgis
Quantum GIS qgis at qgis.org
Tue Feb 3 18:30:57 EST 2009
        Reporter:  alicebtoklas                               |         Owner:  nobody
            Type:  bug                                        |        Status:  reopened
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.0.1
       Component:  Printing                                   |       Version:  1.0.0
      Resolution:                                             |      Keywords:
Platform_version:                                             |      Platform:  Debian
        Must_fix:  No                                         |   Status_info:  0
Changes (by mlennert):
  * status:  closed => reopened
  * resolution:  worksforme =>
Comment:
 Replying to [comment:7 cfarmer]:
 > Tested following the steps outlined above. I am unable to reproduce
 using Ubuntu 8.10.
 > -carson
 I find this a bit quick. The bug can be reproduced both by myself and
 apparently leolami on Debian (Lenny for my part, deb packages just
 installed from the gfoss repository) and by the OP on Ubuntu 8.04. It was
 reported on both the Italian GFOSS list [1] and on the qgis-developers
 list [2].  I don't think that you can just ask everyone to move to Ubuntu
 8.10 and close the bug. It would seem more appropriate to identify the
 problem.
 Maybe it is an issue with different versions of qt ? Did you compile
 yourself, or use the launchpad package ?
 I just tried with an svn checkout of the 1.0.0 branch and I still get the
 same error.
 Moritz
 [1] http://www.nabble.com/problema-con-compositore-di-mappe-in-Qgis-
 td21255539.html
 [2] http://n2.nabble.com/QGIS-1.0:-bug-in-map-composer-td2137920.html
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1479#comment:8>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
