[QGIS-trac] Re: [Quantum GIS] #1479: map composer: adding scalebar when view is added crashes qgis
Quantum GIS qgis at qgis.org
Sun Feb 8 02:53:10 EST 2009
        Reporter:  alicebtoklas                               |         Owner:  nobody
            Type:  bug                                        |        Status:  reopened
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.0.1
       Component:  Printing                                   |       Version:  1.0.0
      Resolution:                                             |      Keywords:
Platform_version:                                             |      Platform:  Debian
        Must_fix:  Yes                                        |   Status_info:  0
Comment (by mhugent):
 Moritz
 I cannot reproduce this problem on any of the systems I have access to
 (which of course does not mean it does not exist). To help trace down the
 problem, you could paste a debugger backtrace. Just run gdb with qgis:
 run 'gdb qgis' in a terminal
 and after the crash, type 'backtrace' and paste the output here.
 If you have a qgis compiled with debugging output enabled, the output will
 be even better, containing line numbers of the relevant source files.
 Marco
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1479#comment:11>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
