[QGIS-trac] Re: [Quantum GIS] #1534: Cannot Select Custom Projection (CRS)
Quantum GIS qgis at qgis.org
Sat Feb 14 16:24:38 EST 2009
        Reporter:  Stephan66                         |         Owner:  nobody
            Type:  bug                               |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:  Version 1.0.1
       Component:  Projection Support                |       Version:  1.0.0
      Resolution:                                    |      Keywords:
Platform_version:  11.1                              |      Platform:  SuSE
        Must_fix:  Yes                               |   Status_info:  0
Comment (by Stephan66):
 Changing the CRS definition to use "+proj=stere" instead of "proj=sterea"
 solves the problem. After that the custom CRS appears under "User defined
 coordinate systems" and can be used for individual layers and the project
 properties.
 The Layer Properties dialog ("General" tab) itself does display the custom
 CRS using "proj=sterea", even when it is entered using "proj=stere".
 I admit I don't know enough about proj4 definition strings to know what
 this change means, but QGIS should be consistent. Shouldn't the test fail
 if using "proj=sterea" makes the definition unusable for QGIS?
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1534#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
