[QGIS-trac] Re: [Quantum GIS] #1534: Cannot Select Custom Projection (CRS)
Quantum GIS qgis at qgis.org
Tue Feb 17 09:03:14 EST 2009
        Reporter:  Stephan66                         |         Owner:  nobody
            Type:  bug                               |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:  Version 1.0.2
       Component:  Projection Support                |       Version:  1.0.0
      Resolution:                                    |      Keywords:
Platform_version:  11.1                              |      Platform:  SuSE
        Must_fix:  Yes                               |   Status_info:  0
Comment (by Stephan66):
 This comment on the subject was posted by user Garvan O'Keeffe on the Qgis
 forum:
 Form msieczka comment to Stephan bug report at the above link, I think the
 correct syntax should be:
 INSERT INTO tbl_projection VALUES("sterea", "Oblique Stereographic
 Alternative","Azimuthal, Sph&Elll", "");
 I uploaded my modified database at the link below, for anybody using Linux
 with Qgis 1.0 who does not know how to edit the database themselves. It
 should recognise sterea with this change. You can delete all the custom
 databases I have, and just add your own.
 http://freefile.kristopherw.us/uploads/sisophon2001/qgis.db
 Garvan
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1534#comment:4>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
