[QGIS-trac] [Quantum GIS] #1489: GRASS Plugin: Map name input field not working correctly for modules that take multiple input maps
Quantum GIS qgis at qgis.org
Fri Jan 16 09:06:53 EST 2009
   Reporter:  benducke                          |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.0.1
  Component:  GRASS                             |            Version:  HEAD
   Keywords:  GRASS, multiple, map names        |   Platform_version:
   Platform:  Debian                            |           Must_fix:  No
Status_info:  0                                 |
 E.g.: open the "r.patch" module dialog. You will see the
 "Type in map names .." field, which works just fine.
 But the "[...]" browse button takes the user to a
 "Save As" dialog, which is completely dysfunctional in
 this context. What it should open is a widget that
 allows users to select one or more maps in the current
 GRASS mapset.
 If that is too much work to go into QGIS 1.0.0, I'd
 suggest getting rid of that button altogether. It
 will be a little inconvenient for the user having
 to manually type in map names, but still better
 than popping up a misleading dialog.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1489>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
