[QGIS-trac] Re: [Quantum GIS] #981: Attribute Table sorting not working as expected
Quantum GIS qgis at qgis.org
Sun Jan 18 20:25:11 EST 2009
        Reporter:  smizuno                           |         Owner:  mhugent
            Type:  defect                            |        Status:  closed
        Priority:  major: does not work as expected  |     Milestone:  Version 1.0.1
       Component:  GUI                               |       Version:  HEAD
      Resolution:  fixed                             |      Keywords:  table sort
Platform_version:                                    |      Platform:  All
        Must_fix:  Yes                               |   Status_info:  0
Changes (by smizuno):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Testing with r9954
 For number types, I have tried a mix of standard numeric notation and
 scientific notation and find that the sorting is correct, as long as there
 aren't the special values (like NaN, Infinity - note that infinity doesn't
 show in the attribute table view). Null cells sort at top or bottom
 depending on sort direction.
 I believe that the special values are not very likely to be seen in the
 GIS world, so I won't pursue this any farther.
 I can't be sure how text columns sort on null values (blank cells) as the
 word NULL is filled in for null data, so all cells have text in them.
 Therefore they sort properly.
 Since numbers now sort properly, I consider this closed.
 Thank you.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/981#comment:3>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
