[QGIS-trac] [Quantum GIS] #1507: fTool dissolve crashes QGIS
Quantum GIS qgis at qgis.org
Sat Jan 24 04:03:18 EST 2009
   Reporter:  hdus                                       |              Owner:  cfarmer
       Type:  bug                                        |             Status:  new
   Priority:  critical: causes crash or data corruption  |          Milestone:  Version 1.0.1
  Component:  Vectors                                    |            Version:  HEAD
   Keywords:                                             |   Platform_version:
   Platform:  Linux                                      |           Must_fix:  Yes
Status_info:  0                                          |
 Use the attached shape for the following steps:
  1. Load Shape gem_poly.shp
  2. Select tools->Geoprocessing Tools->dissolve
  3. Select gem_poly.shp
  4. Select BZRK_NR as dissolve item
  5. Define output shape
  6. Hit OK
 => QGIS Crashes
 I tested it with RedHat AS4 and Kubuntu 8.04. On both boxes QGIS crashes.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1507>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
