[QGIS-trac] Re: [Quantum GIS] #1610: Update Preview in map composer doesn't work
Quantum GIS qgis at qgis.org
Wed Jun 3 10:49:43 EDT 2009
        Reporter:  bjpfei                            |         Owner:  mhugent
            Type:  bug                               |        Status:  closed
        Priority:  major: does not work as expected  |     Milestone:  Version 1.0.3
       Component:  Printing                          |       Version:  HEAD
      Resolution:  wontfix                           |      Keywords:
Platform_version:                                    |      Platform:  RedHat
        Must_fix:  Yes                               |   Status_info:  0
Changes (by mhugent):
  * status:  new => closed
  * resolution:  => wontfix
Comment:
 This is intended behaviour. The extent of a composer map is independent of
 the main map extent. If you want the composer map to adapt to a changed
 main map extent, you need to press 'set to map canvas extent' button in
 the composer map widget.
 Because both extents are different, it is e.g. possible to have multiple
 composer maps in one printout showing different parts of the map or to
 have an overview map at a different scale.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1610#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
