[QGIS-trac] Re: [Quantum GIS] #1721: OS X: grassshell code causing build crash in trunk
Quantum GIS qgis at qgis.org
Fri Jun 5 13:43:35 EDT 2009
        Reporter:  jctull                                     |         Owner:  nobody
            Type:  bug                                        |        Status:  closed
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 2.0.0
       Component:  Build/Install                              |       Version:  HEAD
      Resolution:  invalid                                    |      Keywords:  grass trunk
Platform_version:                                             |      Platform:  OS X
        Must_fix:  No                                         |   Status_info:  0
Changes (by jef):
  * keywords:  grass trunk crash build => grass trunk
  * status:  new => closed
  * resolution:  => invalid
Comment:
 > [ 87%] Building CXX object
 src/plugins/grass/CMakeFiles/grassplugin.dir/qgsgrassshell.o
 > /Users/jctull/sources/qgis/trunk/src/plugins/grass/qgsgrassshell.cpp:35:
 error: expected unqualified-id before ‘<<’ token
 Probably invalid.  At least not reproducable here.
 I bet you have a conflict and '<<' is probably just a piece of the
 introducing {{{<<<<<<< .mine}}}.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1721#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
