[QGIS-trac] Re: [Quantum GIS] #748: Edit vertices within a polygon, polyline vector layers
Quantum GIS qgis at qgis.org
Sat Jun 6 11:12:41 EDT 2009
        Reporter:  jctull                           |         Owner:  nobody
            Type:  enhancement                      |        Status:  closed
        Priority:  minor: annoyance or enhancement  |     Milestone:  Version 1.2.0
       Component:  Digitising                       |       Version:  HEAD
      Resolution:  fixed                            |      Keywords:  edit vertices vector polygon polyline
Platform_version:                                   |      Platform:  All
        Must_fix:  No                               |   Status_info:  0
Changes (by wonder):
  * status:  new => closed
  * resolution:  => fixed
  * milestone:  Version 1.0.3 => Version 1.2.0
Comment:
 Added in r10890. Look for node tool in advanced digitizing toolbar.
 It resembles a tool for editing paths by nodes that is present in every
 vector editor. How does it work:
 - click on a feature, its nodes will be marked by small rectangles
 - clicking and dragging a node moves it
 - double clicking a segment will add a new node
 - pressing delete key will remove active node
 - it's possible to select more active nodes at once: by clicking and
 dragging a rectangle
 - it's possible to select segment's adjacent nodes by clicking on the
 segment
 - it's possible to add/remove active nodes by using Ctrl when clicking a
 node or dragging a rectangle
 Martin
Ticket URL: <https://trac.osgeo.org/qgis/ticket/748#comment:3>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
