[QGIS-trac] Re: [Quantum GIS] #1723: qgis_1_1_0/python/core/qgssymbol.sip:75: syntax error + fix
Quantum GIS qgis at qgis.org
Tue Jun 9 14:55:46 EDT 2009
        Reporter:  neteler                                    |         Owner:  nobody
            Type:  bug                                        |        Status:  closed
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.0.3
       Component:  Build/Install                              |       Version:  1.0.0
      Resolution:  fixed                                      |      Keywords:
Platform_version:                                             |      Platform:  All
        Must_fix:  Yes                                        |   Status_info:  0
Comment (by neteler):
 I am using on Mandriva 2009.1
 gcc -v
 Using built-in specs.
 Target: x86_64-manbo-linux-gnu
 Configured with: ../configure --prefix=/usr --libexecdir=/usr/lib --with-
 slibdir=/lib64 --mandir=/usr/share/man --infodir=/usr/share/info --enable-
 checking=release --enable-languages=c,c++,fortran,objc,obj-c++,java
 --build=x86_64-manbo-linux-gnu --host=x86_64-manbo-linux-gnu --with-
 cpu=generic --with-system-zlib --enable-threads=posix --enable-shared
 --enable-long-long --enable-__cxa_atexit --disable-libunwind-exceptions
 --enable-clocale=gnu --enable-java-awt=gtk --with-java-
 home=/usr/lib/jvm/java-1.5.0-gcj-1.5.0.0/jre --with-ecj-
 jar=/usr/share/java/eclipse-ecj.jar --enable-gtk-cairo --disable-libjava-
 multilib --enable-ssp --disable-libssp --disable-werror
 Thread model: posix
 gcc version 4.3.2 (GCC)
 python-sip-4.7.9-3mdv2009.1
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1723#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
