[QGIS-trac] [Quantum GIS] #1736: After undo node tool symbols are not removed
Quantum GIS qgis at qgis.org
Mon Jun 15 03:25:35 EDT 2009
   Reporter:  hdus                              |              Owner:  wonder
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.2.0
  Component:  Digitising                        |            Version:  HEAD
   Keywords:                                    |   Platform_version:
   Platform:  All                               |           Must_fix:  Yes
Status_info:  0                                 |
 1. load line layer
  2. toggle editing mode
  3. aktivate node tool
  4. select line
  5. select some nodes -> selected nodes are drawn as squares
  6. move the selected nodes -> the squares are moved
  7. click undo -> the moved nodes are removed to the old position
 => the squares with the selected nodes are persistent in the new position.
 Take a look at the attached image.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1736>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
