[QGIS-trac] Re: [Quantum GIS] #1743: Fetch Python plugins menu item non-functional
Quantum GIS qgis at qgis.org
Mon Jun 22 22:00:19 EDT 2009
        Reporter:  jctull                            |         Owner:  nobody
            Type:  bug                               |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:  Version 1.2.0
       Component:  GUI                               |       Version:  HEAD
      Resolution:                                    |      Keywords:  plugin python menu gui
Platform_version:  10.5.7                            |      Platform:  OS X
        Must_fix:  Yes                               |   Status_info:  0
Comment (by jctull):
 On further investigation, the following plugins that I have installed,
 when invoked, do nothing. I can only guess that there might be an api
 method used in the failing modules different from the ones that work.
 Hopefully it will help find the problematic code:
 Geoprocessing Tool
 manageR
 RefMap
 Table Manager
 Zoom to Point
 Copyright Label
 Add delimited Text Layer
 DXF2shp converter
 Interpolate Plugin
 North Arrow
 Quickprint
 Mapserver Export
 Find by Attribute
 Image Map
 Image Boundary
 Mapsheet AutoGeoRef
 MirrorMap
 PostGIS Sql Editor
 These plugins are working:
 SPIT
 PostGIS Manager
 Georeferencer
 OGR Layer Converter
 PGQuery
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1743#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
