[QGIS-trac] Re: [Quantum GIS] #1744: Crash when I save an edited postgis layer
Quantum GIS qgis at qgis.org
Tue Jun 23 07:58:16 EDT 2009
        Reporter:  hdus                                       |         Owner:  jef
            Type:  bug                                        |        Status:  new
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.2.0
       Component:  Data Provider                              |       Version:  HEAD
      Resolution:                                             |      Keywords:
Platform_version:                                             |      Platform:  Debian
        Must_fix:  Yes                                        |   Status_info:  1
Comment (by hdus):
 Replying to [comment:1 jef]:
 > I edit regularly and didn't have any crashes.  Can you give more detail
 about the layers you edit and/or the editing you do?
 > And are you sure the problem appeared with r10863?  The changes therein
 shouldn't affect normal editing.  It should only add more options when
 adding new attributes/columns to a layer/table.
 Yes I'm shure. I updated qgis source with svn up -r10862 and everything
 works fine. When I update with svn up -r10863 QGIS crashes (for further
 information take a look at the attached file).
 All types of layers (Point, Linestring, Polygon) leeds to crash.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1744#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
