[QGIS-trac] [Quantum GIS] #1568: some properties menu items do nothing if certain legend elements selected
Quantum GIS qgis at qgis.org
Mon Mar 9 09:10:47 EDT 2009
   Reporter:  Barryrowlingson                  |              Owner:  nobody
       Type:  bug                              |             Status:  new
   Priority:  minor: annoyance or enhancement  |          Milestone:
  Component:  GUI                              |            Version:  1.0.0
   Keywords:                                   |   Platform_version:
   Platform:  Debian                           |           Must_fix:  No
Status_info:  0                                |
 Load a vector layer. Make sure the legend element is expanded so you can
 see the symbolism.
 Click on the symbolism so a line is highlighted (and the layer name
 _isnt_). Now from the main menu do Layer.. Open Attribute Table. That
 works, up comes the attribute table. Saving as shapefile and saving
 selection as shapefile work. Toggling editing works.
 But do Layer... Properties - nothing happens. Same with Layer... Remove
 layer.
 Also fails with the 'Files' title if you have 'Show File Groups' set, but
 works if you select the files themselves.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1568>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
