[QGIS-trac] Re: [Quantum GIS] #1594: QGIS does not start due to GRASS libraries
Quantum GIS qgis at qgis.org
Wed Mar 25 07:52:26 EDT 2009
        Reporter:  jachym                                     |         Owner:  nobody
            Type:  bug                                        |        Status:  closed
        Priority:  critical: causes crash or data corruption  |     Milestone:
       Component:  Build/Install                              |       Version:  HEAD
      Resolution:  invalid                                    |      Keywords:  grass package ubuntu
Platform_version:  Ubuntu 8.10                                |      Platform:  Debian
        Must_fix:  No                                         |   Status_info:  0
Changes (by marisn):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 If You compile anything against GRASS 6.4 or newer it will NOT run with
 pre-6.4 GRASS libs. Remove pre-6.4 GRASS from LD_LIBRARY_PATH OR remove
 GRASS 6.3.x completely from Your system.
 Closing as it's not a QGIS bug.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1594#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
