[QGIS-trac] [Quantum GIS] #1596: Action tab in vector layer properties does not warn you, if action name is not set
Quantum GIS qgis at qgis.org
Wed Mar 25 15:54:17 EDT 2009
not set
   Reporter:  jachym                            |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:
  Component:  Build/Install                     |            Version:  HEAD
   Keywords:                                    |   Platform_version:
   Platform:  Debian                            |           Must_fix:  No
Status_info:  0                                 |
 If you are adding some action to the vector file and do not set the action
 name (from whatever reason), the action is added to the list of actions,
 you can close the Properties window and try the action in the map. But
 there is no action defined and if you reopen the properties/actions
 diaplog, no action is in the list.
 It would be good to disable the Insert action button, if all input fields
 are not filled with some value.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1596>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
