[QGIS-trac] [Quantum GIS] #1686: QGis crashes if in "printout composer" when I'm trying put scale gadget
Quantum GIS qgis at qgis.org
Tue May 12 06:58:57 EDT 2009
   Reporter:  adamrad                                    |              Owner:  nobody
       Type:  bug                                        |             Status:  new
   Priority:  critical: causes crash or data corruption  |          Milestone:
  Component:  Printing                                   |            Version:  1.0.0
   Keywords:  scale gadget                               |   Platform_version:  Fedora 3 (Qgis 1.0.0, 1.0.1 compiled from src), Windows XP Pro/Home (Qgis 1.0.1 from OSGeo)
   Platform:  Fedora                                     |           Must_fix:  Yes
Status_info:  0                                          |
 When I'm trying put scale gadget onto printout layout in "printout
 composer" I get a QGis crash.
 In Qgis 1.0.0/Qt 4.3.1:
 In Linux console I can see comments like these:
 ============================ I'm inserting a new map window
 ======= Qgis does not crash ==========
 Warning: QgsCoordinateReferenceSystem::getRecord failed :  select * from
 tbl_srs where parameters='+proj=tmerc +lat_0=0 +lon_0=19 +k=0.9993
 +x_0=500000 +y_0=-5300000 +ellps=GRS80 +datum=NAD83 +units=m +no_defs'
 Warning: QgsCoordinateReferenceSystem::findMatchingProj will only work if
 prj acr ellipsoid acr and proj4string are set!...
 Warning: 1
 ============================ I'm inserting scale gadget
 ========== Qgis crashes ======================
 Warning: 2
 Warning: Object::disconnect: Unexpected null parameter
 Fatal: ASSERT failure in QList<T>::at: "index out of range", file
 /usr/local/Trolltech/Qt-4.3.1/include/QtCore/qlist.h, line 386
 This same I got with Qgis 1.0.1/Qt 4.3.3.
 In Windows XP Qgis 1.0.1 from OSgeo crashes in this "place" too.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1686>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
