[QGIS-trac] Re: [Quantum GIS] #1487: QGIS fails to recognise Shapefile projection
Quantum GIS qgis at qgis.org
Thu May 14 10:06:00 EDT 2009
        Reporter:  marisn                            |         Owner:  nobody
            Type:  bug                               |        Status:  closed
        Priority:  major: does not work as expected  |     Milestone:  Version 1.0.2
       Component:  Projection Support                |       Version:  1.0.0
      Resolution:  fixed                             |      Keywords:
Platform_version:                                    |      Platform:  Gentoo
        Must_fix:  No                                |   Status_info:  0
Comment (by hamish):
 a sort of related question about this fix:
 if you have just started the program and this is the first data layer you
 have loaded AND you have not already set the CRS with the "P" setup, will
 it automatically set the uninitialized CRS to match the CRS of the first
 layer, or do you still have to manually adjust the project's CRS to match
 the layers? it would be awesome if that could happen automatically. (maybe
 it now does?)
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1487#comment:5>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
