[QGIS-trac] [Quantum GIS] #1703: No possibility to change color in unique value when assigning more then one class
Quantum GIS qgis at qgis.org
Tue May 19 05:58:05 EDT 2009
class
   Reporter:  bjpfei                            |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.2.0
  Component:  Symbology                         |            Version:  HEAD
   Keywords:                                    |   Platform_version:
   Platform:  RedHat                            |           Must_fix:  Yes
Status_info:  0                                 |
 1.) Load a layer[[BR]]
 2.) Choose unique value in symbology[[BR]]
 3.) press classify[[BR]]
 4.) assign several classes[[BR]]
 [[BR]]
 Problem:  [[BR]]
 - in a polygon layer you can't change the fill color for the assigned
 classes[[BR]]
 - in a line layer you can't change outline style, outline color, fill
 style and fill color[[BR]]
 - in a point layer you can't change outline color, outline width and fill
 color[[BR]]
 Also it seems as it depends on the kind of symbol you have selected what
 happens
 After you have pressed the reset colors button everything works fine
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1703>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
