[QGIS-trac] [Quantum GIS] #2051: Rednering issues in 1.3.0
Quantum GIS qgis at qgis.org
Thu Nov 5 09:47:55 EST 2009
   Reporter:  awooster                          |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.4.0
  Component:  Build/Install                     |            Version:  1.3.0
   Keywords:                                    |   Platform_version:
   Platform:  All                               |           Must_fix:  No
Status_info:  0                                 |
 I've been trying to get me head around this for a while now but seem to
 keep coming back to this as a potential bug but I'm afraid it seems a
 little odd to me, so please excuse the explanation.
  * When I load a single layer - no problems.
  * When I load multiple layers, from any source, with different CRS and
 on-the-fly ticked, the additional layers don't appear on the main area.
  * Zooming to the extent of the invisible layers confirms they are in the
 right place, and adding them to the overlay also confirms this.
 Sometimes, the additional layers appear in the overlay box correctly but
 are still invisible in the main area, sometimes they are invisible but the
 red bounding box in overlay doesn't move when zoom to the extent of a
 hidden layer.
 Changing something on a hidden layer to force QGis to re-render hasn't
 worked so far.
 These layers - generally a mixture of shape files and postgis - worked
 perfectly under earlier releases of QGis.
 The thing which confuses me about this is that when I save an invisible
 layer to a shapefile and load that, its loads in the right place with the
 polygons properly placed. However, the attribute table has been
 distorted.The column headings are correct, but the data after the second
 column has been shifted by one column, with the final colm of data
  - columns 1 & 2 are correct
  - the 3rd column now contains only nulls
  - the 4th contains column 3 data,
  - the fifth column contains column 4 data,
  - etc.
 In case its relevant the reference systems being used are the
 Mapnik/Google (900913) projection as a custom CRS generally used for
 raster images generated by Mapnik, and 27700 OSGB PostGIS and shapefile
 I have QGis 1.3 running under 64-bit Ubuntu 9.04 (and now 9.10) on an AMD
 quad-core with 8Gb RAM - installed from both the QGis unstable repository
 and the UbuntuGIS source. I was able to replicate the issue on a Windows
 XP machine from a copy installed from OSGeo4W.
 I'd be very happy to find it was a mess-up on my behalf but no responses
 on the forum except to report a bug suggests otherwise.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2051>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
