[QGIS-trac] [Quantum GIS] #2055: OSM plugin: incorrect BBOX values used on data download
Quantum GIS qgis at qgis.org
Fri Nov 6 10:56:56 EST 2009
   Reporter:  dankarran                    |              Owner:  borysiasty
       Type:  bug                          |             Status:  new
   Priority:  minor: annoyance             |          Milestone:
  Component:  Python plugins and bindings  |            Version:  1.3.0
   Keywords:                               |   Platform_version:
   Platform:  OS X                         |           Must_fix:  No
Status_info:  0                            |
 If you open layers in QGIS that aren't in WGS84 (e.g. I tried with some
 GeoTIFFs in OSGB36) and then try to download data from OSM to overlay, the
 BBOX uses the coordinates from the original CRS not WGS84 as is needed.
 Can that be forced to use WGS84 to make sure it'll work with OSM?
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2055>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
