[QGIS-trac] [Quantum GIS] #2104: [windows] if the decimal symbol is changed from ", " to "." at o.s. level, then snapping tolerance and vertex search radius are no more configurable
Quantum GIS qgis at qgis.org
Mon Nov 16 15:41:55 EST 2009
#2104: [windows] if the decimal symbol is changed from "," to "." at o.s. level,
   Reporter:  lutra                             |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.4.0
  Component:  Build/Install                     |            Version:  HEAD
   Keywords:                                    |   Platform_version:
   Platform:  Windows                           |           Must_fix:  Yes
Status_info:  0                                 |
 (tested windows xp), then snapping tolerance and vertex search radius are
 no more configurable.
 Using qgis-dev installed with osgeo4w installer
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2104>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
