[QGIS-trac] Re: [Quantum GIS] #2121: trunk compilation errors
Quantum GIS qgis at qgis.org
Thu Nov 19 19:55:48 EST 2009
        Reporter:  neteler                                    |         Owner:  jef
            Type:  bug                                        |        Status:  assigned
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.4.0
       Component:  Build/Install                              |       Version:  HEAD
      Resolution:                                             |      Keywords:
Platform_version:                                             |      Platform:  Mandriva
        Must_fix:  No                                         |   Status_info:  1
Comment (by jef):
 Replying to [comment:6 jef]:
 > and after the first with {{{-k}}} and probably with {{-j}}}.
 > Re-run {{{make -k}}} without {{{-j}}}.  The log of the second run should
 contain all errors.
 ouch.  looks like it's late.
 I meant run {{{make}}} twice.   Once with {{{-k}}} to compile everything
 and not stopping at errors (optionally with {{{-jN}}} for parallel
 compiles).
 On the second run with {{{-k}}} only the errornous stuff is left - and not
 using {{{-jN}}} will avoid messing up the output.  So the log of the
 second run should suffice to report all problems left.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2121#comment:7>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
