[QGIS-trac] Re: [Quantum GIS] #2121: trunk compilation errors
Quantum GIS qgis at qgis.org
Fri Nov 20 01:20:22 EST 2009
        Reporter:  neteler                                    |         Owner:  jef
            Type:  bug                                        |        Status:  assigned
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.4.0
       Component:  Build/Install                              |       Version:  HEAD
      Resolution:                                             |      Keywords:
Platform_version:                                             |      Platform:  Mandriva
        Must_fix:  No                                         |   Status_info:  1
Comment (by neteler):
 Here is the latest output after "make -k":
 [ 32%] Building CXX object
 src/app/CMakeFiles/qgis.dir/qgscontinuouscolordialog.o
 In file included from
 /home/neteler/software/qgis_trunk/src/app/qgscontinuouscolordialog.h:23,
      from
 /home/neteler/software/qgis_trunk/src/app/qgscontinuouscolordialog.cpp:20:
 /home/neteler/software/qgis_trunk/build/src/app/../ui/ui_qgscontinuouscolordialogbase.h:24:25:
 error: qformlayout.h: No such file or directory
      from
 /home/neteler/software/qgis_trunk/build/src/app/../ui/ui_qgscontinuouscolordialogbase.h:32:
 error: ISO C++ forbids declaration of \u2018QFormLayout\u2019 with no type
 error: expected \u2018;\u2019 before \u2018*\u2019 token
 In member function \u2018void
 Ui_QgsContinuousColorDialogBase::setupUi(QDialog*)\u2019:
 /home/neteler/software/qgis_trunk/build/src/app/../ui/ui_qgscontinuouscolordialogbase.h:58:
 error: \u2018formLayout\u2019 was not declared in this scope
 error: expected type-specifier before \u2018QFormLayout\u2019
 error: expected `;' before \u2018QFormLayout\u2019
 make[2]: *** [src/app/CMakeFiles/qgis.dir/qgscontinuouscolordialog.o]
 Error 1
 src/app/CMakeFiles/qgis.dir/qgsgraduatedsymboldialog.o
 /home/neteler/software/qgis_trunk/src/app/qgsludialog.h:22,
      from
 /home/neteler/software/qgis_trunk/src/app/qgsgraduatedsymboldialog.cpp:25:
 /home/neteler/software/qgis_trunk/build/src/app/../ui/ui_qgsludialogbase.h:23:25:
      from
 /home/neteler/software/qgis_trunk/build/src/app/../ui/ui_qgsludialogbase.h:29:
 In member function \u2018void Ui_QgsLUDialogBase::setupUi(QDialog*)\u2019:
 /home/neteler/software/qgis_trunk/build/src/app/../ui/ui_qgsludialogbase.h:47:
 make[2]: *** [src/app/CMakeFiles/qgis.dir/qgsgraduatedsymboldialog.o]
 Error 1
 [ 32%] Building CXX object src/app/CMakeFiles/qgis.dir/qgsludialog.o
      from /home/neteler/software/qgis_trunk/src/app/qgsludialog.cpp:19:
 make[2]: *** [src/app/CMakeFiles/qgis.dir/qgsludialog.o] Error 1
 src/app/CMakeFiles/qgis.dir/qgsmaptoolrotatepointsymbols.o
 /home/neteler/software/qgis_trunk/src/app/qgsmaptoolrotatepointsymbols.cpp:
 In member function \u2018double
 QgsMapToolRotatePointSymbols::calculateAzimut(const QPoint&)\u2019:
 /home/neteler/software/qgis_trunk/src/app/qgsmaptoolrotatepointsymbols.cpp:258:
 error: \u2018atan2\u2019 was not declared in this scope
 error: \u2018M_PI\u2019 was not declared in this scope
 make[2]: *** [src/app/CMakeFiles/qgis.dir/qgsmaptoolrotatepointsymbols.o]
 Error 1
 src/app/CMakeFiles/qgis.dir/qgsvectorlayerproperties.o
      from
 /home/neteler/software/qgis_trunk/src/app/qgsvectorlayerproperties.cpp:27:
      from
 make[2]: *** [src/app/CMakeFiles/qgis.dir/qgsvectorlayerproperties.o]
 Error 1
 src/app/CMakeFiles/qgis.dir/composer/qgscomposer.o
 /home/neteler/software/qgis_trunk/src/app/composer/qgscomposerlegendwidget.h:21,
      from
 /home/neteler/software/qgis_trunk/src/app/composer/qgscomposer.cpp:27:
 /home/neteler/software/qgis_trunk/build/src/app/../ui/ui_qgscomposerlegendwidgetbase.h:
 Ui_QgsComposerLegendWidgetBase::setupUi(QWidget*)\u2019:
 /home/neteler/software/qgis_trunk/build/src/app/../ui/ui_qgscomposerlegendwidgetbase.h:174:
 error: \u2018class QTreeView\u2019 has no member named
 \u2018setHeaderHidden\u2019
 /home/neteler/software/qgis_trunk/src/app/composer/qgscomposer.cpp: In
 QgsComposer::on_mActionExportAsPDF_triggered()\u2019:
 /home/neteler/software/qgis_trunk/src/app/composer/qgscomposer.cpp:459:
 error: \u2018class QPrinter\u2019 has no member named
 \u2018setPaperSize\u2019
 error: \u2018Millimeter\u2019 is not a member of \u2018QPrinter\u2019
 member function \u2018void QgsComposer::on_mActionPrint_triggered()\u2019:
 /home/neteler/software/qgis_trunk/src/app/composer/qgscomposer.cpp:478:
 make[2]: *** [src/app/CMakeFiles/qgis.dir/composer/qgscomposer.o] Error 1
 src/app/CMakeFiles/qgis.dir/composer/qgscomposerlegendwidget.o
      from
 /home/neteler/software/qgis_trunk/src/app/composer/qgscomposerlegendwidget.cpp:18:
 make[2]: ***
 [src/app/CMakeFiles/qgis.dir/composer/qgscomposerlegendwidget.o] Error 1
 src/app/CMakeFiles/qgis.dir/moc_qgscontinuouscolordialog.o
 /home/neteler/software/qgis_trunk/build/src/app/../../../src/app/qgscontinuouscolordialog.h:23,
      from
 /home/neteler/software/qgis_trunk/build/src/app/moc_qgscontinuouscolordialog.cxx:10:
      from
 make[2]: *** [src/app/CMakeFiles/qgis.dir/moc_qgscontinuouscolordialog.o]
 Error 1
 [ 32%] Building CXX object src/app/CMakeFiles/qgis.dir/moc_qgsludialog.o
 /home/neteler/software/qgis_trunk/build/src/app/../../../src/app/qgsludialog.h:22,
      from
 /home/neteler/software/qgis_trunk/build/src/app/moc_qgsludialog.cxx:10:
      from
 make[2]: *** [src/app/CMakeFiles/qgis.dir/moc_qgsludialog.o] Error 1
 src/app/CMakeFiles/qgis.dir/moc_qgscomposerlegendwidget.o
 /home/neteler/software/qgis_trunk/build/src/app/../../../src/app/composer/qgscomposerlegendwidget.h:21,
      from
 /home/neteler/software/qgis_trunk/build/src/app/moc_qgscomposerlegendwidget.cxx:10:
 make[2]: *** [src/app/CMakeFiles/qgis.dir/moc_qgscomposerlegendwidget.o]
 Error 1
 make[2]: Target `src/app/CMakeFiles/qgis.dir/build' not remade because of
 errors.
 make[1]: *** [src/app/CMakeFiles/qgis.dir/all] Error 2
 [ 34%] Built target qgis_analysis
 [ 34%] Built target python
 [ 35%] Built target qgis_help
 [ 35%] Built target qgispython
 [ 35%] Built target memoryprovider
 [ 35%] Built target ogrprovider
 [ 36%] Built target wmsprovider
 [ 36%] Built target delimitedtextprovider
 [ 36%] Built target osmprovider
 [ 37%] Built target postgresprovider
 [ 37%] Built target spatialiteprovider
 [ 38%] Built target gpxprovider
 [ 38%] Built target wfsprovider
 [ 38%] Built target qgisgrass
 [ 38%] Built target grassprovider
 [ 39%] Built target copyrightlabelplugin
 [ 40%] Built target delimitedtextplugin
 [ 42%] Built target interpolationplugin
 [ 42%] Built target northarrowplugin
 [ 43%] Building CXX object
 src/plugins/scale_bar/CMakeFiles/scalebarplugin.dir/plugin.o
 /home/neteler/software/qgis_trunk/src/plugins/scale_bar/plugingui.h:15,
      from
 /home/neteler/software/qgis_trunk/src/plugins/scale_bar/plugin.cpp:52:
 /home/neteler/software/qgis_trunk/build/src/plugins/scale_bar/ui_pluginguibase.h:24:25:
      from
 /home/neteler/software/qgis_trunk/build/src/plugins/scale_bar/ui_pluginguibase.h:31:
 Ui_QgsScaleBarPluginGuiBase::setupUi(QDialog*)\u2019:
 /home/neteler/software/qgis_trunk/build/src/plugins/scale_bar/ui_pluginguibase.h:54:
 /home/neteler/software/qgis_trunk/build/src/plugins/scale_bar/ui_pluginguibase.h:57:
 error: \u2018QFormLayout\u2019 has not been declared
 make[2]: ***
 [src/plugins/scale_bar/CMakeFiles/scalebarplugin.dir/plugin.o] Error 1
 src/plugins/scale_bar/CMakeFiles/scalebarplugin.dir/plugingui.o
      from
 /home/neteler/software/qgis_trunk/src/plugins/scale_bar/plugingui.cpp:12:
      from
 make[2]: ***
 [src/plugins/scale_bar/CMakeFiles/scalebarplugin.dir/plugingui.o] Error 1
 src/plugins/scale_bar/CMakeFiles/scalebarplugin.dir/moc_plugingui.o
 /home/neteler/software/qgis_trunk/build/src/plugins/scale_bar/../../../../src/plugins/scale_bar/plugingui.h:15,
      from
 /home/neteler/software/qgis_trunk/build/src/plugins/scale_bar/moc_plugingui.cxx:10:
      from
 make[2]: ***
 [src/plugins/scale_bar/CMakeFiles/scalebarplugin.dir/moc_plugingui.o]
 Error 1
 make[2]: Target
 `src/plugins/scale_bar/CMakeFiles/scalebarplugin.dir/build' not remade
 because of errors.
 make[1]: *** [src/plugins/scale_bar/CMakeFiles/scalebarplugin.dir/all]
 Error 2
 src/plugins/oracle_raster/CMakeFiles/oracleplugin.dir/qgsselectgeoraster_ui.o
 /home/neteler/software/qgis_trunk/src/plugins/oracle_raster/qgsoracleconnect_ui.h:21,
      from
 /home/neteler/software/qgis_trunk/src/plugins/oracle_raster/qgsselectgeoraster_ui.cpp:18:
 /home/neteler/software/qgis_trunk/build/src/plugins/oracle_raster/ui_qgsoracleconnectbase.h:22:25:
      from
 /home/neteler/software/qgis_trunk/build/src/plugins/oracle_raster/ui_qgsoracleconnectbase.h:27:
 Ui_OracleConnectGuiBase::setupUi(QDialog*)\u2019:
 /home/neteler/software/qgis_trunk/build/src/plugins/oracle_raster/ui_qgsoracleconnectbase.h:45:
 make[2]: ***
 [src/plugins/oracle_raster/CMakeFiles/oracleplugin.dir/qgsselectgeoraster_ui.o]
 Error 1
 [ 44%] Building CXX object
 src/plugins/oracle_raster/CMakeFiles/oracleplugin.dir/qgsoracleconnect_ui.o
      from
 /home/neteler/software/qgis_trunk/src/plugins/oracle_raster/qgsoracleconnect_ui.cpp:17:
      from
 make[2]: ***
 [src/plugins/oracle_raster/CMakeFiles/oracleplugin.dir/qgsoracleconnect_ui.o]
 Error 1
 src/plugins/oracle_raster/CMakeFiles/oracleplugin.dir/moc_qgsoracleconnect_ui.o
 /home/neteler/software/qgis_trunk/build/src/plugins/oracle_raster/../../../../src/plugins/oracle_raster/qgsoracleconnect_ui.h:21,
      from
 /home/neteler/software/qgis_trunk/build/src/plugins/oracle_raster/moc_qgsoracleconnect_ui.cxx:10:
      from
 make[2]: ***
 [src/plugins/oracle_raster/CMakeFiles/oracleplugin.dir/moc_qgsoracleconnect_ui.o]
 Error 1
 make[2]: Target
 `src/plugins/oracle_raster/CMakeFiles/oracleplugin.dir/build' not remade
 because of errors.
 make[1]: *** [src/plugins/oracle_raster/CMakeFiles/oracleplugin.dir/all]
 Error 2
 [ 45%] Built target rasterterrainplugin
 [ 46%] Built target quickprintplugin
 [ 47%] Built target coordinatecaptureplugin
 [ 48%] Built target dxf2shpconverterplugin
 [ 49%] Built target ogrconverterplugin
 [ 52%] Built target diagramoverlay
 [ 54%] Built target evis
 [ 54%] Building CXX object
 src/plugins/labeling/CMakeFiles/labelingplugin.dir/labeling.o
 /home/neteler/software/qgis_trunk/src/plugins/labeling/labeling.cpp: In
 member function \u2018virtual void
 LabelingTool::canvasPressEvent(QMouseEvent*)\u2019:
 /home/neteler/software/qgis_trunk/src/plugins/labeling/labeling.cpp:83:
 error: \u2018class QMouseEvent\u2019 has no member named \u2018posF\u2019
 make[2]: ***
 [src/plugins/labeling/CMakeFiles/labelingplugin.dir/labeling.o] Error 1
 make[2]: Target `src/plugins/labeling/CMakeFiles/labelingplugin.dir/build'
 not remade because of errors.
 make[1]: *** [src/plugins/labeling/CMakeFiles/labelingplugin.dir/all]
 Error 2
 [ 56%] Built target spitplugin
 [ 57%] Built target gpsimporterplugin
 [ 58%] Built target wfsplugin
 [ 58%] Building CXX object
 src/plugins/georeferencer/CMakeFiles/georefplugin.dir/qgspointdialog.o
 /home/neteler/software/qgis_trunk/src/plugins/georeferencer/qgsgeorefwarpoptionsdialog.h:19,
      from
 /home/neteler/software/qgis_trunk/src/plugins/georeferencer/qgspointdialog.cpp:35:
 /home/neteler/software/qgis_trunk/build/src/plugins/georeferencer/ui_qgsgeorefwarpoptionsdialogbase.h:22:25:
      from
 /home/neteler/software/qgis_trunk/build/src/plugins/georeferencer/ui_qgsgeorefwarpoptionsdialogbase.h:27:
 Ui_QgsGeorefWarpOptionsDialogBase::setupUi(QDialog*)\u2019:
 /home/neteler/software/qgis_trunk/build/src/plugins/georeferencer/ui_qgsgeorefwarpoptionsdialogbase.h:40:
 make[2]: ***
 [src/plugins/georeferencer/CMakeFiles/georefplugin.dir/qgspointdialog.o]
 Error 1
 src/plugins/georeferencer/CMakeFiles/georefplugin.dir/qgsgeorefwarpoptionsdialog.o
      from
 /home/neteler/software/qgis_trunk/src/plugins/georeferencer/qgsgeorefwarpoptionsdialog.cpp:16:
      from
 make[2]: ***
 [src/plugins/georeferencer/CMakeFiles/georefplugin.dir/qgsgeorefwarpoptionsdialog.o]
 Error 1
 src/plugins/georeferencer/CMakeFiles/georefplugin.dir/moc_qgsgeorefwarpoptionsdialog.o
 /home/neteler/software/qgis_trunk/build/src/plugins/georeferencer/../../../../src/plugins/georeferencer/qgsgeorefwarpoptionsdialog.h:19,
      from
 /home/neteler/software/qgis_trunk/build/src/plugins/georeferencer/moc_qgsgeorefwarpoptionsdialog.cxx:10:
      from
 make[2]: ***
 [src/plugins/georeferencer/CMakeFiles/georefplugin.dir/moc_qgsgeorefwarpoptionsdialog.o]
 Error 1
 make[2]: Target
 `src/plugins/georeferencer/CMakeFiles/georefplugin.dir/build' not remade
 because of errors.
 make[1]: *** [src/plugins/georeferencer/CMakeFiles/georefplugin.dir/all]
 Error 2
 [ 66%] Built target grassplugin
 [ 67%] Built target pluginstaller
 [ 67%] Built target mapserverexport
 [ 67%] Built target ftools
 [ 68%] Built target osmplugin
 [ 70%] Built target ftools_tools
 make[1]: Target `all' not remade because of errors.
 make: *** [all] Error 2
 make: Target `default_target' not remade because of errors.
 [  0%] Built target svnversion
 [  7%] Built target ui
 [ 23%] Built target qgis_core
 [ 31%] Built target qgis_gui
      from
      from
 Error 1
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2121#comment:8>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
