[QGIS-trac] [Quantum GIS] #2127: NG Symbol property color change freezes qgis
Quantum GIS qgis at qgis.org
Fri Nov 20 13:23:58 EST 2009
   Reporter:  jctull                                     |              Owner:  wonder
       Type:  bug                                        |             Status:  new
   Priority:  critical: causes crash or data corruption  |          Milestone:  Version 1.4.0
  Component:  Symbology                                  |            Version:  HEAD
   Keywords:  symbol properties freeze ng                |   Platform_version:  10.6.2
   Platform:  OS X                                       |           Must_fix:  Yes
Status_info:  0                                          |
 On my OS X machine with qt-4.6, trying to change the color for a vector
 layer using ng-symbology's  is freezing the application. Upon further
 testing, it appears to be an intermittent issue. For example, changing the
 fill color on a polygon layer will work, from the "Change" button on the
 main symbology window. But opening the Properties dialog and changing the
 color from the Symbol properties dialog will cause the freeze. This makes
 it impossible to create new symbol styles or do more than change the fill
 color for the default polygon symbol.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2127>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
