[QGIS-trac] [Quantum GIS] #2130: problem with render caching (disabled) after using the field calculator
Quantum GIS qgis at qgis.org
Fri Nov 20 15:23:19 EST 2009
   Reporter:  lutra                             |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.4.0
  Component:  MapCanvas                         |            Version:  HEAD
   Keywords:                                    |   Platform_version:
   Platform:  All                               |           Must_fix:  No
Status_info:  0                                 |
 To replicate:
 add a layer, use the field calculator do some kind of column operation,
 toggle editing to save changes. Starting from now things goes wild, as
 feature selection, toggle editing on, etc. all works only after a refresh
 of the map.
 Tested with trunk on both linux and windows.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2130>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
