[QGIS-trac] Re: [Quantum GIS] #2154: Not correctly creating (or reading) proj file for CRS for EPSG 2193
Quantum GIS qgis at qgis.org
Fri Nov 27 15:44:43 EST 2009
        Reporter:  mesajs                            |         Owner:  nobody
            Type:  bug                               |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:  Version 1.4.0
       Component:  Projection Support                |       Version:  HEAD
      Resolution:                                    |      Keywords:  CRS
Platform_version:  Vista 64                          |      Platform:  Windows
        Must_fix:  No                                |   Status_info:  0
Comment (by mesajs):
 Cedric
 You are right. Providing an explicit extension does fix the
 problem.[[BR]][[BR]]
 Even stranger: If I do not give the extension, then QGIS creates a
 subfolder of the same name and places the shapefile components there.
 [[BR]][[BR]]
 EG. If I select folder "C:\QGIS" and save as "myshapfile.shp" (explicit
 extension), then I get files "C:\QGIS\myshapefile.shp",
 "C:\QGIS\myshapefile.prj" etc. But if I select folder "C:\QGIS" and save
 as "myshapfile" (no extension), the files are
 "C:\QGIS\myshapefile\myshapefile.shp" etc. - folder C:\QGIS\myshapefile is
 created.[[BR]]
 [[BR]]
 Is this another bug?[[BR]]
 [[BR]]
 Tony
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2154#comment:9>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
