[QGIS-trac] Re: [Quantum GIS] #2160: "on the fly" reprojection distorts calculated polygon area
Quantum GIS qgis at qgis.org
Sat Nov 28 14:09:53 EST 2009
        Reporter:  belg4mit                          |         Owner:  nobody
            Type:  bug                               |        Status:  closed
        Priority:  major: does not work as expected  |     Milestone:  Version 1.4.0
       Component:  Projection Support                |       Version:  1.0.2
      Resolution:  wontfix                           |      Keywords:
Platform_version:                                    |      Platform:  Windows
        Must_fix:  No                                |   Status_info:  0
Changes (by lutra):
  * status:  new => closed
  * resolution:  => wontfix
Comment:
 if you are using 1.0.2, please update to 1.3 (or trunk) as there were
 major bug fixes in the projection/measurement section since the version
 you are using.
 If even with 1.3/trunk you will experience problems than please post a
 sample of your data in order to make further tests.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2160#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
