[QGIS-trac] Re: [Quantum GIS] #2154: Not correctly creating (or reading) proj file for CRS for EPSG 2193
Quantum GIS qgis at qgis.org
Mon Nov 30 00:58:37 EST 2009
        Reporter:  mesajs                            |         Owner:  nobody
            Type:  bug                               |        Status:  closed
        Priority:  major: does not work as expected  |     Milestone:  Version 1.4.0
       Component:  Projection Support                |       Version:  HEAD
      Resolution:  fixed                             |      Keywords:  CRS
Platform_version:  Vista 64                          |      Platform:  Windows
        Must_fix:  No                                |   Status_info:  0
Comment (by mesajs):
 Replying to [comment:12 cmoe]:
 Cédric[[BR]]
 I like the idea of raising an enhancement. Could be extended to cover
 other inconsistencies in "save" dialogs:[[BR]]
 1. Behavior should not depend on whether or not user types in the .shp
 extension[[BR]]
 2. All dialogs should behave the same. Like ftools, "Save as shapefile"
 (on layer menu) does not create a sub-directory, but Table Manager plugin
 does).[[BR]]
 3. The qml file (save default layer properties) is added to level above
 above the new sub-directory (also fixed in R12290???).[[BR]]
 3. Print composer "save" dialogs for saving maps as image, pdf, or SVG do
 not add extensions. But "Save as image" from the file menu on the main
 main qgis window does add the extension[[BR]]
 Tony
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2154#comment:14>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
