[QGIS-trac] [Quantum GIS] #2166: with render caching enabled the overview goes wild
Quantum GIS qgis at qgis.org
Mon Nov 30 17:19:06 EST 2009
   Reporter:  lutra                             |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.4.0
  Component:  Map Legend                        |            Version:  HEAD
   Keywords:                                    |   Platform_version:
   Platform:  All                               |           Must_fix:  Yes
Status_info:  0                                 |
 Enable render caching in qgis options, then add a vector layer (I always
 use the "world borders" shape to make such tests) and then add the layer
 to the overview.
 Many times, but not always, the overview immediately goes wild showing a
 wrong extent. If you then try resize the overview window it seems to fix
 the problem, but then you can notice empty spaces between the countries.
 If the overview doesn't go immediately wild you can do the following:
 change symbology to the vector (old or new symbology doesn't matter), then
 remove the vector from the overview and add it again (to see the overview
 with the new symbology). Now the overview goes wild.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2166>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
