[QGIS-trac] Re: [Quantum GIS] #1918: Edit -> options crashes application
Quantum GIS qgis at qgis.org
Thu Sep 3 12:40:52 EDT 2009
        Reporter:  iknowjoseph                                |         Owner:  nobody
            Type:  bug                                        |        Status:  new
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.3.0
       Component:  Build/Install                              |       Version:  1.2.0
      Resolution:                                             |      Keywords:
Platform_version:                                             |      Platform:  Debian
        Must_fix:  No                                         |   Status_info:  0
Comment (by iknowjoseph):
 Installed from the ppas:
 https://launchpad.net/~qgis/+archive/unstable
 joseph at joseph-work:~$ sudo apt-get install qgis
 Reading package lists... Done
 Building dependency tree
 Reading state information... Done
 The following extra packages will be installed:
   libqgis1.2.0 qgis-common qgis-plugin-grass qgis-plugin-grass-common
 The following NEW packages will be installed
   libqgis1.2.0 qgis qgis-common qgis-plugin-grass qgis-plugin-grass-common
 0 upgraded, 5 newly installed, 0 to remove and 3 not upgraded.
 Need to get 6375kB/17.2MB of archives.
 After this operation, 41.8MB of additional disk space will be used.
 Do you want to continue [Y/n]? y
 Get: 1 http://ppa.launchpad.net jaunty/main qgis-plugin-grass-common
 1.2.0-1~jaunty1 [6375kB]
 Fetched 6375kB in 9s (658kB/s)
 Selecting previously deselected package libqgis1.2.0.
 (Reading database ... 202922 files and directories currently installed.)
 Unpacking libqgis1.2.0 (from .../libqgis1.2.0_1.2.0-1~jaunty1_i386.deb)
 Selecting previously deselected package qgis-common.
 Unpacking qgis-common (from .../qgis-common_1.2.0-1~jaunty1_all.deb) ...
 Selecting previously deselected package qgis.
 Unpacking qgis (from .../qgis_1.2.0-1~jaunty1_i386.deb) ...
 Selecting previously deselected package qgis-plugin-grass-common.
 Unpacking qgis-plugin-grass-common (from .../qgis-plugin-grass-
 Selecting previously deselected package qgis-plugin-grass.
 Unpacking qgis-plugin-grass (from .../qgis-plugin-
 grass_1.2.0-1~jaunty1_i386.deb) ...
 Adding `diversion of /usr/bin/qgis to /usr/bin/qgis.bin by qgis-plugin-
 grass'
 Processing triggers for man-db ...
 Processing triggers for shared-mime-info ...
 Unknown media type in type 'all/all'
 Unknown media type in type 'all/allfiles'
 Unknown media type in type 'uri/mms'
 Unknown media type in type 'uri/mmst'
 Unknown media type in type 'uri/mmsu'
 Unknown media type in type 'uri/pnm'
 Unknown media type in type 'uri/rtspt'
 Unknown media type in type 'uri/rtspu'
 Unknown media type in type 'fonts/package'
 Unknown media type in type 'interface/x-winamp-skin'
 Processing triggers for menu ...
 Setting up libqgis1.2.0 (1.2.0-1~jaunty1) ...
 Setting up qgis-common (1.2.0-1~jaunty1) ...
 Setting up qgis-plugin-grass-common (1.2.0-1~jaunty1) ...
 Setting up qgis (1.2.0-1~jaunty1) ...
 Setting up qgis-plugin-grass (1.2.0-1~jaunty1) ...
 Processing triggers for libc6 ...
 ldconfig deferred processing now taking place
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1918#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
