[QGIS-trac] Re: [Quantum GIS] #1919: Plugin installer (version 1.0.1) fails to load
Quantum GIS qgis at qgis.org
Thu Sep 3 13:05:25 EDT 2009
        Reporter:  iknowjoseph                       |         Owner:  borysiasty
            Type:  bug                               |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:  Version 1.3.0
       Component:  Python plugins and bindings       |       Version:  1.2.0
      Resolution:                                    |      Keywords:
Platform_version:                                    |      Platform:  Debian
        Must_fix:  No                                |   Status_info:  0
Comment (by iknowjoseph):
 Thanks, apt-get install'ing that helped (see below for output)
 Is python-qgis not an explicit dependency? Should it not have been
 installed as part of my original installation?
 Thanks again, Joseph
 joseph at joseph-work:~$ sudo apt-get install python-qgis
 Reading package lists... Done
 Building dependency tree
 Reading state information... Done
 The following packages were automatically installed and are no longer
 required:
   libqgis1.0.2
 Use 'apt-get autoremove' to remove them.
 The following extra packages will be installed:
   python-qgis-common
 The following packages will be upgraded:
   python-qgis python-qgis-common
 2 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
 Need to get 1161kB of archives.
 After this operation, 3310kB of additional disk space will be used.
 Do you want to continue [Y/n]? y
 Get: 1 http://ppa.launchpad.net jaunty/main python-qgis 1.2.0-1~jaunty1
 [472kB]
 Get: 2 http://ppa.launchpad.net jaunty/main python-qgis-common
 1.2.0-1~jaunty1 [689kB]
 Fetched 1161kB in 1s (768kB/s)
 (Reading database ... 204602 files and directories currently installed.)
 Preparing to replace python-qgis 1.0.2-1~jaunty3 (using .../python-
 qgis_1.2.0-1~jaunty1_i386.deb) ...
 Unpacking replacement python-qgis ...
 Preparing to replace python-qgis-common 1.0.2-1~jaunty3 (using .../python-
 qgis-common_1.2.0-1~jaunty1_all.deb) ...
 Unpacking replacement python-qgis-common ...
 Setting up python-qgis-common (1.2.0-1~jaunty1) ...
 Setting up python-qgis (1.2.0-1~jaunty1) ...
 Processing triggers for libc6 ...
 ldconfig deferred processing now taking place
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1919#comment:4>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
