[QGIS-trac] Re: [Quantum GIS] #1658: Python binding unavailable/MacOS X universal binaries (two bugs)
Quantum GIS qgis at qgis.org
Fri Sep 4 19:12:10 EDT 2009
        Reporter:  vince                             |         Owner:  nobody
            Type:  bug                               |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:  Version 1.0.3
       Component:  Build/Install                     |       Version:  HEAD
      Resolution:                                    |      Keywords:
Platform_version:                                    |      Platform:  OS X
        Must_fix:  No                                |   Status_info:  0
Comment (by kyngchaos):
 Just starting to take a second look at this.  There isn't much we can do,
 really.  The architectures is meaningless here, because sipconfig only
 takes the 'universal' SDK option, which triggers it to add the arch flags
 hardwired into SIP (universal 32bit only).  So, if you want a 64bit Qgis
 python module, you need to hack and compile SIP 64bits.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1658#comment:8>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
