[QGIS-trac] Re: [Quantum GIS] #1943: ftools/buffer produce result shape with wrong crs parameters
Quantum GIS qgis at qgis.org
Tue Sep 22 09:49:08 EDT 2009
        Reporter:  cmoe                              |         Owner:  cfarmer
            Type:  bug                               |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:  Version 1.4.0
       Component:  Python plugins and bindings       |       Version:  HEAD
      Resolution:                                    |      Keywords:  crs; buffer; ftools
Platform_version:                                    |      Platform:  All
        Must_fix:  Yes                               |   Status_info:  0
Changes (by lutra):
 * cc: homann (added)
  * owner:  nobody => cfarmer
  * priority:  critical: causes crash or data corruption => major: does not
               work as expected
  * component:  Vectors => Python plugins and bindings
  * platform:  RedHat => All
Comment:
 This is weird.
 I'm using qgis 1.3 and 1.4 trunk under Ubuntu 9.04
 I apparently see no problems (with or without OTFR enabled), even if as a
 fact the towgs84 parameter is missing in the resulting layer projection.
 I see also that other layers resulting from other ftools operation seem to
 miss the towgs84 if present in the source layer.
 Not sure where the problem may reside, if in the plugin or in the
 projection component.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1943#comment:3>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
