[QGIS-trac] [Quantum GIS] #1955: QGis segfaults unless I am root
Quantum GIS qgis at qgis.org
Mon Sep 28 19:18:07 EDT 2009
   Reporter:  rnolde                                     |              Owner:  nobody
       Type:  bug                                        |             Status:  new
   Priority:  critical: causes crash or data corruption  |          Milestone:
  Component:  Build/Install                              |            Version:  1.0.2
   Keywords:  segfault                                   |   Platform_version:  Fedora 11
   Platform:  Fedora                                     |           Must_fix:  No
Status_info:  0                                          |
 QGis Stable(qgis-1.0.2-1.fc11.i586) on Fedora 11 with Grass
 6.3.0-12.fc11.i586 will run as root but segfaults at startup with a normal
 user login.  If I startup Grass separately, I get the following message:
 Starting GRASS ...
 /usr/lib/python2.6/site-packages/wx-2.8-gtk2-unicode/wx/_core.py:14450:
 UserWarning: wxPython/wxWidgets release number mismatch
   warnings.warn("wxPython/wxWidgets release number mismatch")
 I've rebuilt QGis from the src RPM with no change. I have run strace qgis
 and captured the output to see what files are being opened by qgis before
 it crashes.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1955>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
