[QGIS-trac] Re: [Quantum GIS] #1864: Saving projects with relative paths
Quantum GIS qgis at qgis.org
Tue Sep 29 13:53:00 EDT 2009
        Reporter:  gislab                            |         Owner:  jef
            Type:  bug                               |        Status:  closed
        Priority:  major: does not work as expected  |     Milestone:  Version 1.4.0
       Component:  Project Loading / Saving          |       Version:  HEAD
      Resolution:  fixed                             |      Keywords:  relative paths
Platform_version:                                    |      Platform:  Unix
        Must_fix:  No                                |   Status_info:  0
Changes (by jef):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Replying to [comment:2 lutra]:
 > Sorry to have to reopen this ticket, but saving with relative paths
 seems not work any more, at least under Linux (testing under Ubuntu 9.04)
 with both qgis 1.3 from repos and 1.4 trunk compiled.
 I wonder when this happend.  Apparently that never worked on Linux.
 > Made simple tests with shapefiles and when the "save absolute paths" is
 not checked
 if you can check "save absolute paths" you are using something < r11729.
 Which should have fixed this issue.  Feel free to reopen, if it didn't.
 > ./path/to/shape.shp
 > instead of
 > path/to/shape.shp
 the {{{./}}} is perfectly fine.  {{{.}}} is the current directory.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1864#comment:4>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
