[QGIS-trac] Re: [Quantum GIS] #2932: GdalTools: improve Build Overviews dialog by adding more options, and translatable Translate dialog
Quantum GIS qgis at qgis.org
Fri Aug 6 19:18:50 EDT 2010
   Reporter:  dcarreira         |              Owner:  brushtyler
       Type:  patch             |             Status:  assigned
   Priority:  minor: annoyance  |          Milestone:  Version 1.6.0
  Component:  Build/Install     |            Version:  Trunk
   Keywords:  GdalTools, GDAL   |   Platform_version:
   Platform:  All               |           Must_fix:  No
Status_info:  0                 |
Changes (by brushtyler):
  * status:  new => assigned
Comment:
 Should the JPEG quality be enabled only if the "Overviews in TIFF with
 JPEG compression" is checked, isn't it?
 And if the input image is not a GeoTIFF, what happen? We should disable
 the "Overviews in TIFF..." checkbox in that case.
 By testing the input file format, if it's not Erdas Imagine we can
 disable/enable also the "overview in .aux file".
 We have to mind about this before applying the patch. Your opinions?
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2932#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
