[QGIS-trac] Re: [Quantum GIS] #2955: Would be very useful to be able to move text along a road
Quantum GIS qgis at qgis.org
Thu Aug 19 06:52:17 EDT 2010
   Reporter:  infobleep                         |              Owner:  jef
       Type:  enhancement                       |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.6.0
  Component:  Vectors                           |            Version:  1.5.0
   Keywords:  move, text, road, path, clashing  |   Platform_version:
   Platform:  All                               |           Must_fix:  No
Status_info:  0                                 |
Comment(by infobleep):
 Thank you for your reply. I have tested out the new labelling engine.  I
 tested both the newer one and the standard built in one. However even with
 the new labelling engine it isn't possible to manually move the labels.
 A distance can be set but as every label will require a different distance
 and/or position, since not all text clashes are precisely at the same
 point each time, this is not workable.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2955#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
