[QGIS-trac] Re: [Quantum GIS] #3286: Qgis segfaults instanciating QgsComposition from python
Quantum GIS qgis at qgis.org
Fri Dec 3 12:06:13 EST 2010
   Reporter:  elpaso                                     |              Owner:  mhugent
       Type:  bug                                        |             Status:  new
   Priority:  critical: causes crash or data corruption  |          Milestone:  Version 1.7.0
  Component:  Python plugins and bindings                |            Version:  Trunk
   Keywords:  QgsComposition                             |   Platform_version:  ubuntu lucid 64bit
   Platform:  Linux                                      |           Must_fix:  No
Status_info:  0                                          |
Comment(by elpaso):
 Hi, I tested your patch but it still crashes. BTW I suspect it's a bug in
 QT and I found a way to make it work, it seems like QGraphicsScene (from
 which QgsComposition inherits, needs a QApplication instance, so this line
 needs to be added before the call to QgsComposition constructor.
 app = QtGui.QApplication(sys.argv, QtGui.QApplication.Tty)
 I thought having called QgsApplication.initQgis would have been enough to
 have a QApplication instance.
 You can probably close this bug.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3286#comment:3>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
