[QGIS-trac] Re: [Quantum GIS] #2166: with render caching enabled the overview goes wild
Quantum GIS qgis at qgis.org
Tue Dec 7 13:07:07 EST 2010
   Reporter:  lutra                             |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.7.0
  Component:  Map Legend                        |            Version:  Trunk
   Keywords:                                    |   Platform_version:
   Platform:  All                               |           Must_fix:  Yes
Status_info:  0                                 |
Changes (by lutra):
  * milestone:  Version 1.6.0 => Version 1.7.0
Comment:
 it seems that is still true with the actual trunk r14856.
 After adding a layer it does not show in the overview window unless OTFR
 is activated. If you activate OTFR after having added the layer, then the
 overview show something but the canvas extent goes wild. In this case
 using "zoom to layer" does not help, it is needed to give a "touch" with
 the pan tool and the canvas extent return more or less normal.
 If OTFR is activated before adding the layer (and adding it to the
 overview) then the overview shows the layer but very very small...
 basically useless... and there is no way to recover the situation, even
 trying with "zoom to layer" or other tools.
 With render caching enabled the crashes when resizing the overview window
 are still confirmed... but this is another problem already described in
 another ticket.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2166#comment:3>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
